uh60james
- February 19, 2006
- Fayetteville, NC
- '93 Sport (Dora), '06 XLT
I bought a 93 sport less than a month ago and now have everything working pretty good. New shocks, tires and fixed the 4wd shift motor. The vehicle has a Ford Vehicle Security System installed on it, I assume not factory as the module was not bolted down and you have to push a button to start the explorer. The problem is it didn't come with a remote! I can't find a part number anywhere on the module.
There is an 18 pin accessory harness connector, a 5 pin door lock connector, a 4 pin shock sensor connector and a 2 pin starter connector. I would like to find a new remote or if the connections are standard to all ford systems or even some aftermarket systems just replace the module and get new remotes with it that way.
