Batx00
- April 12, 2017
- Idaho
- 2001, Explorer, 5.0, XLT
Hi everyone, I bought a 2001 explorer xlt 5.0 a few weeks ago and noticed the front vents won't stop blowing air unless you turn the vent selector switch to off. This is manually controlled system, not the electric unit. When you put the switch in any position, it does redirect the air flow according but the front vents are always blowing air to some degree. The only way to shut the front vents off is to either turn the switch to off (thus turning off the whole system) or close the air flow flapper at each vent. Temperature control hot to cold works. The variable blower fan speed works. I looked behind the glove box and the actuator is opening/closing the door all the way depending on the mode. I checked behind the radio and everything is plugged in and looks fine. Could there be something inside the heater box stopping it from shutting the front vents all the way off? Do I need a new switch assembly? Is there a way to test the electrical part of the switch? Any ideas?
