Jack5219
- April 2, 2010
- 1994 sport 4x4
I'm new to this forum, new to owning an explorer and a bit new to the DIY auto repair. I recently bought a 94 X sport 4x4 with a manuel trans. It runs great with only one problem. Whenever it gets up around 65 mph it gets a really bad vibration. It gets worse the faster it goes. If I take my foot off the gas it's still there. The vibration only goes away when the truck slows. It is the same in 4th gear and in overdrive. It seems to be worse on bumpy or uneven pavement. In the last month I have replaced all 4 shocks, replaced the rear leaf spring shackles, and repacked and tightened the front wheel bearings. I checked the drive shaft, the u-joints seem good and spug although I did notice a slight leek in the rear dif behind the pinion flange. Nothing seems to be helping. Does anyone have an idea what could be causing the vibration?
