PDA1
- October 28, 2004
- PA
- '96 XLT
Car- Explorer XLT- 1991
Odometer- 191,000
I'm fairly certain I've got excessive vibration in the front wheels/bearings which has recently developed. It "feels" like I'm pulling a heavy load...like the drive train is working very hard.
The Vibration begins at around 20 MPH.
With either the right or left FRONT sides jacked up I get tire movement of about 1/8" when pushing in at the top of the tire and pulling out on the bottom of the tire simultaneously (90 degrees to the road). I get little or no tire movement applying the same method on the left and right side of the tire (parallel to the road).
There are no loose upper and lower ball joints and no loose tie rod ends.
How can I determine if the vibration problem is caused by wheel bearings (either front or rear)?
The tires are wearing fine with no abnormal wear patterns.
Odometer- 191,000
