Georgie
- June 3, 2006
- montreal canada
- 99 XL
Hi all,
Had a oil leak at the front diff coming from the pinion seal. The companion flange was grooved so i got a new one from ford and reused the old crush sleeve, never took it out. Also reused the nut. Put locktight and followed the procedure to remove wheels and brakes, then use a inch pound dial torque wrench and got within spec of 14-23 inch/lb (for old crush sleeve). Also went ahead and installed the new seal and drained and filled up with royal purple.
Started her up and its been running perfect with no leaks for the last 500 miles.
Yesterday i started to get vibrations when accelerating. Cruising nothing. Feel it mostly between 1800-3000 rpm...30-50 mph. I don't know what to do.
I went under and disconnected the front drive shaft from the pinion and flipped it. It got a little better but still getting vibrations... any ideas?
The only thing i can think of is something in the front diff that's getting effed up...
Thanks
Thanks
