XxxMonoxideChild
- April 6, 2008
- Rockford, IL
- 92 pile
the entire time ive owned the explorer, the voltage gance liked to dance around. not fast or anything, or jumpy, but i wouldnt be surprised to watch the voltage gauge drop from 14.5 down to 8-9 volts just sitting at a stop sign.
well since its allways done it, but never actually done anything to make me think it ACTUALLY was running on 8 volt's, i assumed faulty sending unit and kinda blew it off.
that changed.. lol. about a week ago, i was waiting outside while my g/f ran into a store for something. noticed the low voltage, then suddenly the radio turned off! that got me worried, cause right away i knew the truck might die, and it WASNT just a bad sending unit.
i ordered the alt, picked it up, but hadnt had time to install it. well, my g/f took the truck out into chicago yesterday for work, she called me saying the radio shut off, and the truck is acting wierd. i told her to leave the radio off, turn the lights, and a/c off, and pray she makes it back... she called back 5 min later, she didnt make it back... it died coming to a stop i guess.
it took her over an hour to find someone to assist with a jump start. (i at least tossed a set of jumpers in it just in case) and she was able to get it home thankfully.
well i swapped out the alt last night, but the voltage is still going as low as 7 volts at times! (i allways thought a car couldnt even run on anything less then 8 volts?) ive also very recently replaced the battery, and battery cables, and all connections are tight. wiring itself isnt damaged or gunked up.
