beendooben
- February 16, 2010
- Avenel, NJ
- 97 5.0 Explorer AWD XLT
Having a issue with the idle on my 97 X 5.0 AWD. This morning on the way into work i heard a lil pinging. Massaged the gas a little and the trans downshifted and would not shift correctly. came to a light with the motor taching up to around 3000 rpms then went down. Stopped for a cup of coffee and when the truck was in park had a high idle up and around 3k again. Shut the truck off got the coffee started the truck again and the idle was bouncing all over the place. real low-high then mellowed out. Put the truck in gear and was fine. Got to work shut the truck off started it back up and the idle was all over the place. went to shift into gear and the idle mellowed out. the past few days the truck when cold would idle fine until it was put into reverse then the idle would raise then go down as the truck warmed up. Any ideas would be very helpful.
Thanks in advance.
Thanks in advance.
