Warped Rotors? Or something worse?
Dupontrocks11
Clemson, SC
2001 Ford Explorer Sport
I've been putting a lot of miles on my Ex recently, and I've noticed that it tends to kind of *lurch* when I have my foot on the brake at low speeds. I don't feel much on the brake petal, but I do feel vibrations in the steering wheel.
Things to note, the engine has stalled 3 times on start up since I've gotten it a couple months ago. Usually turning it off and starting it up again fixes it, and it drives like a dream.
Also, when I'm stopped at a red light sometimes before the engine warms up, I can hear it kind of rev pulsing. The rev counter doesn't change, but I can still hear it.
Anyways, any suggestions would be helpful. It's not really a huge problem, but fixing it would be nice. I'm about to drive back down to school, which is about a 900+ mile car ride, and I want to fix all the issues before I leave.
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
J_C
Florence, KY
1998 XLT 4WD 4.0L SOHC
Definitely pull the codes but yes that's likely to be warped rotor(s). You may as well pull the front wheels and have a look at the brake components, and might rotate the tires while you're at it if they're nearly due for it.
J Can over tightening lugs cause warped rotors? Stock 1995 - 2001 Explorers 4
D Warped rotors==noise? Stock 1995 - 2001 Explorers 0
E Front Brake Rotors warped again? Stock 1995 - 2001 Explorers 11
C Cracked & warped cylinder heads Stock 1995 - 2001 Explorers 5
J Warped air filter box Stock 1995 - 2001 Explorers 2
S 98 explorer HELP!!! NEW alternator put in, mechanic says stuck in "anti theft" stealth mode **UPDATE**WAS THE STARTER -NOW BALL BEARINGS BRAKES/ROTORS Stock 1995 - 2001 Explorers 47
L pads rotors Stock 1995 - 2001 Explorers 10
E Rear rotors recommendation Stock 1995 - 2001 Explorers 5
B All new rotors/pads and right front is rubbing?!?! Stock 1995 - 2001 Explorers 15
T Need rear rotors for 2003 Ford Explorer XLT Sport 4.0 Stock 1995 - 2001 Explorers 1
A Canadian Market brake rotors different than US market for our trucks? Stock 1995 - 2001 Explorers 8
K 2004 Ford Explorer Sport trac front brake rotors minimum thickness Stock 1995 - 2001 Explorers 3
S Which rotors and pads for 1997 V8 AWD? Stock 1995 - 2001 Explorers 3
D Question on brakes and rotors Stock 1995 - 2001 Explorers 4
K Great and easy way to remove stuck rotors Stock 1995 - 2001 Explorers 13
C Front Rotors Rusted and Seized - 2000 Explorer Stock 1995 - 2001 Explorers 14
T Source for Brembo rotors Stock 1995 - 2001 Explorers 4
S Correct Rotors/pads for 2000 Sport? Stock 1995 - 2001 Explorers 11
shadowless127 What are the best rotors and pads to use? Stock 1995 - 2001 Explorers 7
T Opinions on Summit Racing Rotors Stock 1995 - 2001 Explorers 2
B rear brake rotors seize to Ford 8.8 axle Stock 1995 - 2001 Explorers 19
8 New Rotors/Pads - Now NO pedal Stock 1995 - 2001 Explorers 24
E pads & Rotors Stock 1995 - 2001 Explorers 2
R Informal Survey: Best brand for rotors for 2001-2005 Explorer? Stock 1995 - 2001 Explorers 0
M Front rotors TURNED BLUE!? Stock 1995 - 2001 Explorers 30
mounty71 Brake Rotors--Bosch Quietcast? Stock 1995 - 2001 Explorers 11
Tbars4 95-01 Rear Brake Rotors Question Stock 1995 - 2001 Explorers 4
B Brake Heat, Rotors, Pad Types Stock 1995 - 2001 Explorers 7
B Brake Rotors, Front One-Piece, 2000 Explorer Stock 1995 - 2001 Explorers 11
A New Brake Pads/Rotors Shakes Stock 1995 - 2001 Explorers 4
T anyone replacing rotors - I want your tone ring Stock 1995 - 2001 Explorers 8
R Front rotors or front hub bearings??? Stock 1995 - 2001 Explorers 0
shadowless127 Grinding when braking - new pads/rotors Stock 1995 - 2001 Explorers 6
H Powerslot rotors & hawk pads - Q. Stock 1995 - 2001 Explorers 3
G '96 xlt 4dr 2WD V/8 brake rotors Stock 1995 - 2001 Explorers 3
toypaseo $102.39 Brembo Sport Slotted Rotors or $154.97 Centric Powerslots? Stock 1995 - 2001 Explorers 0
0 Rear Rotors Stuck 99 EB AWD Stock 1995 - 2001 Explorers 14
T Cross drilled/slotted rotors worth the money? Stock 1995 - 2001 Explorers 16
B 1997 Mounty Cant get rear rotors off Stock 1995 - 2001 Explorers 15
D Squeaky Brake Pad After New Pads and Rotors Stock 1995 - 2001 Explorers 6
toypaseo Raybestos Professional Grade rotors and pads good? Stock 1995 - 2001 Explorers 7
D Replacing Front Rotors. Stock 1995 - 2001 Explorers 3
2 Who has powerslot rotors? Stock 1995 - 2001 Explorers 3
R Front rotors worn out unevenly Stock 1995 - 2001 Explorers 16
F new pads on worn rotors Stock 1995 - 2001 Explorers 9
C Brembo or Powerslot rotors? Stock 1995 - 2001 Explorers 14
R What type and brand of pads and rotors work best Stock 1995 - 2001 Explorers 7
J Time for new front rotors....need advice, please Stock 1995 - 2001 Explorers 2
Afboy143 Problem with new rotors Stock 1995 - 2001 Explorers 3
M Front brake rattle after putting in new pads and rotors Stock 1995 - 2001 Explorers 9
Similar threads
