Warrior 153 shackles install with pics
ILM_explorer
Wilmington nc
95 eddie
Will the warrior 153 shackles work on a 95 Eddie?
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
ILM_explorer
Wilmington nc
95 eddie
For anyone know if i could fit 32's on my 95 Eddie with the lift shackles and torsion twist?
zero_psi
mi b hills
93 xlt svt
if i want to make my own shackles dose any one have any dimensions i should use if i want a full 2 inches of rear lift? and the thickness of steel i should use?
gmanpaint
It's Always Something!
Staff member
Moderator
MO MO
94 & 95 XLT's
Yes
Yes. Might have to trim a little off the fender behind the tire.
For both of you guys....
The condition of your leaf springs will make a difference in the height gained. Weak / worn springs will lose lift faster than fresh maximum arched springs. If your leafs are old and worn, this is just a temp bandaid and eventually your going to need to replace the leaf packs. These shackles work best on a fresh set of springs for max lift to clear larger tires.
tjsxplodr
Idaho
1991 Ford Explorer XLT
has anyone found online shackles longer than the standard 1.25"? I want to go 2" or 2.5".
RedneckRambo
Sterling, Colorado
1994 Explorer XLT
just do shackles and AAL its not that much more of a rough ride
zero_psi
mi b hills
93 xlt svt
So any ideas on the specs on the shackles it looks stupid with just the front lifted lol
Schobanger
Fargo, ND
'97 Explorer Sport
do the wheels need to come off before this? or can they be kept on? taking them off wont be such a pain considering most people do the TT with the shackle placement so they need an alignment anyway. just a quick question
gmanpaint
Staff member
Moderator
MO MO
94 & 95 XLT's
2 bars of 3/8" x 10.25" L x 2" W
1/2" bolt holes are 9.5" apart from center to center.
Middle support bar is 1/4" thick sq tube x 3"L x 2" x 1.5" welded between the bars. The center tube is not centered in the middle of the brackets. It is 1" closer to one end then the other for the offset.
Leave the wheels on for install. ;)
MidnightRebel07
Pittsburgh, Pa.
2003 Explorer Sport Trac
Gman, is this what you're talking about?
MidnightRebel07
Pittsburgh, Pa.
LOL, I've posted this picture a couple times in different threads. I figured this would help out in this one too.
snapp central
Vancouver, B.C. (born & raised); Prince George - seasonally
97 5.0 limited &97 ""SOHC
30 mins???
Obviously you don;t have to deal with road salt and winter: )
I think it took me three days to get everything dismantled, using WD-40 PB blaster, heater, an impact gun and 3 foot breaker bar. In the end I had to replace the bushings in the frame side of the mount because the metal sleeve had become one with the shackle bolt and separated from the bushing when I removed the bolt.
no kidding.. must be nice.... ; my 97 limited has been used continually to towing and backing down into water at boat launch ramps... This wasn't the first time Ive done something like this (did add a leaf 2 months ago) and this took me around 4 -5 hours a side with all the essentials. .. my shackles are destroyed and flattened ... will post some pics.. had to cutt one bolt cuz was seized just too much. .. crazy but so glad its done.. oh man
snapp central
great post. nice to have your pics and write up... used it tons when installing on mine.. although took 4 plus hours a shackles to simple get off.. cheers
tjsxplodr
Idaho
No way! Too stiff! I got a 94 that I'm gonna use my coil spacers and shackles on, wish me luck on getting those old bolts off lol.
RedneckRambo
Sterling, Colorado
1994 Explorer XLT
i have coil spacers shackles and an AAL its not that bad. you get used to it pretty quick
tjsxplodr
Idaho
Now for the big question, shocks. What length are the stock ones and how am I going to find out what size I need for the rear since I will be raising the truck 2"? I'm not familiar with shocks at all, and so have no idea what I'm looking for.
RedneckRambo
Sterling, Colorado
1994 Explorer XLT
i just relocated mine to the sway bar mount on the rear axle.
MidnightRebel07
Pittsburgh, Pa.
I kept mine at the stock location and haven't had any issues in over 4 years. You don't really need to relocate the shocks to the swaybar bracket unless you do a SOA (Spring Over Axle) conversion. JMO.
RedneckRambo
Sterling, Colorado
1994 Explorer XLT
only reason i did is because i flex mine out a lot
B Anyone know if the Warrior 153 shackles fit a Ranger? Shocks, Suspensions, Lift Kits 8
JamminG4Jim Warrior 153 Shackles and Pinion angle Shocks, Suspensions, Lift Kits 3
H Do you have warrior 153's? Shocks, Suspensions, Lift Kits 12
rhyno Just installed Warrior 153, didnt do much Shocks, Suspensions, Lift Kits 3
E Trying to install warrior spring shackles Shocks, Suspensions, Lift Kits 11
MidnightRebel07 I'm buying used Warrior Products lift shackles, no bolts. What size are the bolts? Shocks, Suspensions, Lift Kits 4
L Are Warrior Shackles still the choice of most on here? I'm looking to get a set soon. Shocks, Suspensions, Lift Kits 4
J Wanted Warrior Shackle Info and other lift questions Shocks, Suspensions, Lift Kits 9
Y Warrior shackles Shocks, Suspensions, Lift Kits 8
N Quick question regarding Warrior Shackle & TT Shocks, Suspensions, Lift Kits 3
D Warrior shackle lift Shocks, Suspensions, Lift Kits 3
G Where can I find warrior shackles? Shocks, Suspensions, Lift Kits 6
A shackles-other than warrior Shocks, Suspensions, Lift Kits 15
3 Warrior shackles and TT? I'm new to this!!! Shocks, Suspensions, Lift Kits 2
A Warrior shackle length Shocks, Suspensions, Lift Kits 5
N Warrior Sway Bar Disconnects Shocks, Suspensions, Lift Kits 9
2 TT and Warrior Shackles Shocks, Suspensions, Lift Kits 22
S Warrior Shackle Install - Before and after pics Shocks, Suspensions, Lift Kits 7
S Does anyone have pics of Warrior shackles from behind? Shocks, Suspensions, Lift Kits 8
D Cheap warrior 153s? Shocks, Suspensions, Lift Kits 3
9 pic of warrior shackles installed on 2nd gen? Shocks, Suspensions, Lift Kits 9
T warrior shackel and hidden hitch ? Shocks, Suspensions, Lift Kits 1
E Help ! Spec. Warrior Shakles Shocks, Suspensions, Lift Kits 14
C warrior shackles Shocks, Suspensions, Lift Kits 16
I Warrior Shock Mounts Shocks, Suspensions, Lift Kits 3
C Warrior Shackles Shocks, Suspensions, Lift Kits 14
B A warrior shackle question Shocks, Suspensions, Lift Kits 2
I Warrior Shackles...Where to buy? Shocks, Suspensions, Lift Kits 2
B Ordered Warrior Shackles will i have to get rid of my Rancho5000 Shocks, Suspensions, Lift Kits 5
B URGENT QUESTION ON WARRIOR SHACKLES........ Shocks, Suspensions, Lift Kits 7
9 warrior shackels instal ? Shocks, Suspensions, Lift Kits 1
9 will my warrior shackles fit Shocks, Suspensions, Lift Kits 16
G Busted warrior u-bolt skid plate - how do i fix it? Shocks, Suspensions, Lift Kits 4
H Question about warrior shackles Shocks, Suspensions, Lift Kits 1
L Tellico has an overstock on Warrior Shackles. Shocks, Suspensions, Lift Kits 22
T AAL and Warrior Installation Shocks, Suspensions, Lift Kits 4
B JD Shock and Warrior Shackle Questions Shocks, Suspensions, Lift Kits 4
B warrior shackles Shocks, Suspensions, Lift Kits 3
M Warrior Shackles question..... Shocks, Suspensions, Lift Kits 8
W Are the Warrior shackles on 1.25" lift? Shocks, Suspensions, Lift Kits 4
W What is the part number for the warrior shackles? Shocks, Suspensions, Lift Kits 2
Kirby N. Opinions on Warrior Quick Discos Shocks, Suspensions, Lift Kits 10
M Torsion twist and warrior shackles? Shocks, Suspensions, Lift Kits 3
B Shortening warrior shackles... Shocks, Suspensions, Lift Kits 10
E warrior shackles/tt Shocks, Suspensions, Lift Kits 3
W warrior quick disconnect noise problem? Shocks, Suspensions, Lift Kits 9
B Front B bars lift to warrior lift Shocks, Suspensions, Lift Kits 0
S Ballpark Warrior Shackle price? Shocks, Suspensions, Lift Kits 2
L Torson Twist, Warrior Shackles and leaf bundles, a Fresh Look Shocks, Suspensions, Lift Kits 20
F Where to find Warrior Shackels on Net or Denver Area...Helpmae Shocks, Suspensions, Lift Kits 8
Similar threads
