1999 ExplorerXLS
- August 4, 2008
- Goose Bay,N.L.
- '99 XLS
I am having no luck with this washer pump.I press in on the multi-function switch and the wipers come on and no fluid,and the same thing for the rear window.
1-I've checked the relays under the air filter,switched them with two from the fog lamp relays that I know work,and nothing.
2-switched the relay in the main fuse box in the engine compartment with one I know that works and nothing.
3-I noticed that the wires on the conector that joins onto the pump itself were wore a bit,i.e. small hole with some wires broken inside.I took apart the connector and replaced the wires,still nothing.
4-Checked the small fuse in the fuse panel in the dash,looks ok to me.No burning or scorching visible.
5-Multi-f@#kup switch,I mean multi-function switch....I've tried 2 other switches from other Ford's before I checked everything else.
6-I ran a wire from the battery directly to the pump,that works.
Is there something I am missing?Should I dig out the other 2 switches and try them now that I have tried everything else?
