washer pump | Ford Explorer - Ford Ranger Forums - Serious Explorations
washer pump
steves97z28
MA
98 explorer XLT
First off I have done some searching but still a bit confused. The washer pump is not working on my 98 xlt...It does not work for either the front or the rear wipers. When I hit either switch the wipers work but i get no washe fluid. At the pump you can not hear the pump working. I took a new pump from work and pluged it in, pressed the button and still could not hear the pump running. I tried swapping the relays around in the box on the passenger side frame rail with no luck. I guess it could still be a fuse but I do not have a layout of the fuse box so I do not know which fuses control what. Any ideas of where to look? I thought the stalk could be the problem but cant figure out why the button for the rear wouldnt work if the problem was in the stalk its self.
steves97z28
MA
98 explorer XLT
