Eric Z
- November 28, 2017
- Plymouth Minnesota
- 15 Explorer PIU
I am looking for some help. 2015 PIU with the 3.7L and just 60,000 miles and less than 500 idle hours. Vehicle was running normal, parked it and came back 30 minutes later to find puddle of brownish fluid underneath. Looked under hood and found the coolant tank had overflowed and was full of oil and coolant mixture. I assumed catastrophic water pump failure and had it towed to Ford dealer. Service Manager called and said water pump NOT the problem but that the engine oil cooler had burst, which allowed the oil to mix with the coolant (as that was under higher pressure). He said the oil level was low, but that the oil itself was clean. Now engine was running normal at shutdown, no low oil pressure warning, etc. So then comes the bad news.... The quoted cost for repair is over $3,200.00, with $1,300 of that for a radiator and $487 for engine oil cooler, $620 for upper and lower radiator hoses, $230 for the coolant expansion tank, $200 for cooling flush, $90 for serpentine belt and $90 for engine clean. It seems like they are trying to replace anything that came in contact with the coolant and oil mixture, except the heater core, but wondering if that is overkill?? And if the engine oil cooler is separate from the radiator, why can't that just be flushed, why replace at $1,300?? Same with the hoses, wouldn't a good flush clean them out??
