Water last weekend, now it won't start.
Byrd91
Penobscot, Maine
'92 XLT
I went through some deep water last weekend, maybe 18"-20" and now my car won't start. I get all the accessory lights and the fuel pump runs, but when I turn to start I just get the loud click. Do you think this has to do with the water, or has the starter just gone bad??? Any help would be greatly appreciated. Oh yeah, I've had it running a few times this week too. Started normally.
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Sounds like a classic bad connection at the starter. Have you tried arching the starter solenoid? This will send more power to the starter then the key will, it may get you going.
Mine would start when it would get hot, I ended up re-doingthe entire wiring down at the starter, I soldered the small lead toteh starter and I soldered the O ring connector to the wire instead of just the crimp connection it had. I also ran new wires and installed yet another starter solenoid. This fixed it for along time, but the other day it did it again! I just pop the hood, put the key in the on postition and jump the solenoid, starts right up. I need a new starter. The 4.0L starter has a built in solenoid, I fear this is my problem. I had a new starter in there but when I converted to an automatic I had to go back to an auto starter and I didnt have the $$$ so my auto starter has about 140K miles on it.
It;s the connection at the starter...I'll bet you $5.
Also may be the perfect time to replace that sucker.....
Byrd91
Penobscot, Maine
'92 XLT
How would I go about jumping the starter solenoid. Is that the one right next to the battery on the inner fender?
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
Thats right. Basically there are three wires.
The small red/blue wire is the signal wire from the key switch that activated the solenoid. It;s working because you are hearing a click.
The one post is the + wire directly from the battery. You can follow it for 10" and see it goes right to the + post.
The wire on the other post of the solenoid (should be alone)is the one that goes to the starter, This is the signal wire to the starter that tells the starter to crank. The starter then also has a 10 guage wire that goes directly to the + battery post as well. So you see you actually have two starter solenoids, except one is built into the starter, this most likely is what is going out on your truck.
Use a screwdriver or pocket knife, make sure the key is in the ON position and the truck is in PArk or NEAutral (Stick) and arch the two starter solenoid posts together, the starter will bump. If it does, it could be your fender mounted solenoid is bad (doubt it)
the reason the starter may crank is because you are simply sending a little more juice to it's built in solenoid and thus you can get a few more miles out of it....
Try it and let me know if it works. If not, you can test the fednder mounted solenoid, if that checks out it;s rebuilt starter time! About $80 at a local alternator/starter guy.
Byrd91
Penobscot, Maine
'92 XLT
Ok jumped the solenoid and got it to start. Also turned it off and got it to start with the key after a couple times with the clicking, so I'm guessing its all down in the starter built in solenoid....how hard is it to change a starter....
JDraper
Somewhat Functional
Moderator Emeritus
McVeytown, PA
'18 XLT
Starter is pretty easy to change. Disconnect the battery, disconnect the wires from the starter, unbolt the starter and drop it out. Put new starter in in reverse order. Should take less than an hour. It helps if you put the vehicle on ramps first.
C SOHC- How long does a water pump last? Under the Hood 2
E 91-94 water pumps, how long they last? Under the Hood 22
M 2007 4.0 Explorer Water Pump Life Expectancy? Under the Hood 2
Number4 Cyl 4 not "water tight" Under the Hood 1
R Noise from water pump area Under the Hood 0
S DIY water methanol injection system and controller Under the Hood 1
M water guage Under the Hood 1
S Cracked T-stat housing but no water visible? Under the Hood 0
1 4.0l sohc missing water pump bolts and dipstick Under the Hood 0
T '96 Explorer V8 Thermostat Housing / Water Outlet - 90 degree same as 95 Mustang V8 Under the Hood 0
Tbars4 How To: Ranger 2.3L water pump Under the Hood 8
J 98 Explorer V8 Water pump bolt broke at block Under the Hood 5
L oil in water 97 exployer Under the Hood 7
C Water in Oil Under the Hood 3
J Oil n Water in Plug wells Under the Hood 3
S Water out the tail pipe and running hot... Under the Hood 3
C Driving in deep water, now my ex sounds weird :( Under the Hood 8
0 Water Pump Under the Hood 5
E How to snorkle and water seal? Under the Hood 0
4 Water/Methanol Injection Kit Under the Hood 4
RangerX Will a bad water pump leak with the engine off? Under the Hood 8
E Electric water pump and fan Under the Hood 1
D water pump??? Under the Hood 2
N 5.0L Explorer water pump (broke stud) Under the Hood 9
A 96 4.0 Oil in the water, engine runs ok Under the Hood 4
S water pump Under the Hood 45
D muddy water! Under the Hood 2
V effect of hho water fouling plugs or injectors Under the Hood 1
C 98 Explorer 5.0 Water Pump problem Under the Hood 4
7 Hydrobooster (run your Ex on water) - your opinions please! Under the Hood 2
B Water 4 Fuel? Under the Hood 1
B Buddy's 1999 Ford xplorer took in water Under the Hood 6
T Water leak - '98 4.0 SOHC V6--HELP!!ASAP Under the Hood 2
F Help. Question about water Pump 5.0 Under the Hood 2
D Water damage to fuel injectors? Under the Hood 4
B Anti-freeze or Water? Under the Hood 5
L Water in the oil Under the Hood 2
E water for gas Under the Hood 30
Y Water pump seal or weep hole location?? ( HELP) Under the Hood 2
V Water in the motor Under the Hood 1
K Major Water Leaking - Please Help Quickly Under the Hood 4
J Water Temp Gauge not working at all. Under the Hood 16
aldive Water pump flow rate Under the Hood 7
P Intake gasket water leak? Under the Hood 6
M What is causing my water pump shaft to leak? Under the Hood 7
K Is water pump shot or can it be fixed? Under the Hood 3
9 Autometer water and tranny temp gauges installation Under the Hood 3
X6StringerX Water in gas? Under the Hood 13
rookieshooter electric water pump? Under the Hood 11
I water pump recommendations? Under the Hood 7
Similar threads
