My car has been leaving a small puddle of water in the cargo area after it rains. It honestly doesn't happen all the time but more often than not.
I have seen water run down the seatbelt in 3rd row so i know its coming in around there.
Today i decided to pull this thing apart. Not very easy with all seats + air matress installed but to it.
Image IMG-20210903-141009 hosted in ImgBB
ibb.co
So i can see water stains right where the seatbelt mounts up top. I remove the seatbelt and got better look. There are only two possible culprits i could identify...
1) Rear hatch wiring harness grommet
2) Body joint molding/sealant on roof
The body joint/sealer is located directly above the grommet area so it could just be dripping onto the grommet. I decided to put RTV around the grommet inner channel.
Image IMG-20210903-140943 hosted in ImgBB
ibb.co
Image IMG-20210903-141034 hosted in ImgBB
ibb.co
Does anyone have a similar leak and what did you find? I'm keeping this apart until I can confirm it is fixed. The rust on the rear cross brace is clear indicator this has been going on for a while. Time to end it...
