Water pump Bleed port Location? | Ford Explorer - Ford Ranger Forums - Serious Explorations
walterd140
Ludlow, Massachusetts
'94 Sport
Got a leak at / near the water pump & I don't know if it is the heater hose or bleed port. Where is the water pump bleed port located as I look down into the front of the motor? 12 o'clock being the top of the pump, 9 o'clock the passanger side of the x.
Any help? Fluid dripping at about the heater hose connection at about 10 o'clock. If I can locate the bleed, then I can figure out what is the issue (hose or pump)
Walter
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
rugbum
Indianapolis
'93 XLT & '93 Sport
I have 2 93' explorers and i have had the pump off on both, i dont believe that they have bleeder valves. Best bet is that its the hose.
Maniak
Moderator-Stock 91-94
Moderator Emeritus
Vail, Arizona
1992 XLT 4x4
There is a weep hole on the water pumps for the 1st gen X. I had a water pump loose the interal seal and water was coming out of the water pump quite fast from the weep hole.
I can't remember where on the pump it was.. it was years ago.. I have my old motor sitting on the ground by the shed.. I can take a look at it if you really need to know where the weep hole is.
~Mark
walterd140
'94 Sport
If it's not too much of a bother Mark, I would appericate it.
Thanks
Walter
Rattosh51
St. Paul, MN
1992 XLT 94 F150
Weep holes are usually at 6 o'clock...
ricco750
Springfield, MO USA
'93XLT4X2 (3:27 LimSlip)
Yep, that's where it is...I'm currently on my 3rd WP, probably about ready for another.:usa:
Maniak
Moderator Emeritus
Vail, Arizona
1992 XLT 4x4
I finally got some non rainy weather to uncover the old motor. The weep hole is not on the top, left or right side.. I can't see underneath since the motor is sitting on a tire on the ground.
~Mark
suprcharg97
westland mi
water pump weep hole location
if you have the time, visit the parts store and they will have a replacement pump you can look at.
