Water pump replacement | Ford Explorer - Ford Ranger Forums - Serious Explorations
coreman23
Big Bear, CA
92 XLT
I've decided to tackle the job of replacing my water heater. I got a replacement and from the instructions here, I think I could do it myself.
My question is what else should I go ahead and change while I'm in there? I got a new thermostat, plan on getting new idler and tensioner pulley's. (Should I replace the whole tensioner assembly?)
I plan on replacing the radiator hoses, top and bottom.
Anything else?
Iron Weasel
Belen, New Mexico
1994 XLT 4x4
Serpentine belt.
Roadrunner777
Bemidji, MN
94 4x4 Sport 88k
Take a good look at your fan, look for blade cracks/problems. I'm about 50/50 when it comes to electric fans, but if you have thought of doing it, now would be the time.
Either way, sure you know, but don't forget those special wrenches...
marragtop
balt, md
91, 92, 95, and 2000 xlts
Definetely do the serp belt if it's old. As mentioned, consider the fan.
coreman23
Big Bear, CA
92 XLT
I changed the serpertine belt last year, so that should be good to go. I'll consider the fan, I may just replace it, we'll see how it looks.
mr cribb
US Army Retired
Harviell, MO
94 Chevy Z71, 93 X EB
Anything else?
Hoses and new clamps.... most overlooked item in a cooling system. (sorry I just seen you're gonna change them)
huntman58
Fremont calif.
2013 Dodge Advenger
Heater hoses and any by pass hoses also. Most forget them and they will leak or blow just as fast as the upper or lower will and leave you just as broke down.
Even if you replaced the belt not that long a go I would do it again and just hold on to the one you takes off as an emergency spare. I keep two with me one for with AC and one for with out been doing this for years and it paid off one time so far also.
rustbucketMI
Michigan
'94 XLT 4x4
If you have everything apart anyway it is a good idea to do a radiator flush, there are a lot of posts on here about suggestions for the best way.
