Wrangler95CSA
- August 1, 2014
- Summerville, SC
- 2000 Ford Explorer
Greetings again! 2000 Eddie Bauer Explorer V8 with 106k miles on it. After replacing the radiator and all hoses, I filled it to do a coolant flush. Shortly after it started I noticed I had a leak where the bypass hose connects to the water pump. Upon further inspection, I discovered that I had a hole in the inlet to the water pump about the size of a match head, so I had to kill the engine and stop the flush (all the water and cleaner is still in the system). Unfortunately I don't have the time to be able to do a water pump change, so I wanted to see what you guys think about this: if I were to JB Weld the hole in the water pump inlet neck, do you think it will hold long enough for me to limp it to the nearest garage about a mile and a half away?
Thanks in advance for all your input!
