Waze will be available in 3.0!!! | Ford Explorer - Ford Ranger Forums - Serious Explorations
Mooton
San Francisco, CA
2017 Explorer Platinum
Ford integrates Waze navigation app in Sync 3
This is amazing news for Apple CarPlay users! I'm curious how it will work with CarPlay, though. It's not a CarPlay app - it's a native Sync 3 app. But can CarPlay be enabled while Waze is available? Or does CarPlay need to be disabled first? Sort of how you can't use Sync 3's Navigation unless CarPlay is disabled.
In any event, tip of the cap to Ford for making this happen.
Has anyone with a pre-released version of 3.0 or a 2018 with 3.0 seen this actually work?
ilguy
Chicago
Maybe this means they will finally launch the SMARTLINK service they announced at CES last year!
Mlarv5
Crossville TN
2017 Platinum Ruby Red
Ford supports it from V2.3 and on. Currently Waze does not have the correct interface SW to make it work. Should be out around March. This I just finished reading on the F150forum.
Mooton
San Francisco, CA
I just went through that F150 thread and there were several references to Waze making this available in March (though I couldn't find that mention in Waze's press release). It also sounded like that may sync up with Ford's official release of 3.0 which is, in the words of a Ford person I spoke with yesterday, "a few weeks away if all goes well". And given that 2.3 doesn't add any real functionality over 2.2, I would expect 3.0 to be a requirement.
ilguy
Chicago
Maybe I'm reading too much in to it but for all of the pre-2018 sync 3 users that don't currently have a cellular enabled (SMARTLINK) car, I would assume SMARTLINK would be required for the Waze connectivity so it can send and receive the data without the smartphone attached as the presser suggests.
thefranchise713
Buffalo, NY
'18 Toyota Prius Prime
It's running through AppLink, not CarPlay, and it shouldn't require SmartLink because Waze's connectivity would be coming through the phone running it.
Mooton
San Francisco, CA
That's the way I understand it. And AppLink (or at the least, this Waze app) requires a USB connection since it's mirroring the app from the phone and that amount of data cannot be transferred quickly enough over Bluetooth.
suzook
ny
2018 Explorer XLT
Just got my new 2018 XLT, and figuring out what the deal with waze is. Do i need android auto working? Or does it run on its own?
15Limited
TN
2018 Sport 4x4
You have Waze working/on on your phone then plug your phone into your vehicle...Waze will then display on your Sync screen.
suzook
ny
2018 Explorer XLT
OK, Thanks. There's a nice "hack" using an old android phone with your new one to make Android auto wireless. If it works out, I will post results here.
thefranchise713
Buffalo, NY
It should be an app that can run natively on Sync 3, without Android Auto or CarPlay. You may need to go into Apps on the Sync 3 screen and tell it to scan/find apps on your phone.
jhu8
Maryland
2022 Ford Explorer ST
Post this hack!! :)
Also for android, you need to have AA setup. I think it is only Apple where waze can run standalone. But I heard its pretty bad. But yeah, post the wireless android hack. Would love to check that out.
suzook
ny
2018 Explorer XLT
Post this hack!! :)
[Android 3.0+]Proxy/GateWay for Android Auto
I got it working once, but after a restart I have to completely reset everything. The Dev is still working on it. Would be nice to just jump in your car, and AA just connects.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Your thread was moved here. There are a few more on Waze.
Argentimage
MI
2005 Limited
do not know why the Ford's would be lagging but in a Lincoln, the waze app is better than native on the phone, it has short cuts to report accidents and 'other' items, on touch instead of having to hit two or three on the phone, need to call the hot line that should be listed in the SYNC quick start to get help, if you don't ask, you won't receive.
