Web worm attacks Windows, spreads fast
Campo
Elitus Explorus
White City, KS
99 XLT 4x4
cochino12
denver, co
2001 sport
what exactly is happening?
IAmTodd
4x Explorer Veteran
Johnstown, PA
2001 Jeep Cherokee
God is windows update slooooow! What exactly does this virus do?
Brans Freestyle
Northridge, CA
'01 Ranger 4x4
The virus messes a lot of things up. I work at a computer store and we've been getting calls all day about this thing. It goes in thru like port 185 or something, and then makes windows shut down. What ive been seeing is people will start their computers up, and then like 2 min later message says blah blah somethings wrong, windows will shut down and then your computer restarts.
my friend although got the same thing and now he cant even boot into windows, so this one can mess you up.
IAmTodd
4x Explorer Veteran
Johnstown, PA
2001 Jeep Cherokee
Good then, the only port i have open is for my website, and its not 185 :D The advantages of having DSL:p
Brans Freestyle
Northridge, CA
'01 Ranger 4x4
I just checked and found out that it is 135 not 185. And if you have a router you should be fine, and windows update will fix it if you don't have it. A way to check if you have it is to search for the file msblast. If you have it, just rename is to msblast.exe or anything like that and you should be fine.
dejello
perpetually unconcious
College Station, TX
If I'm thinking about the same thing
The techs up at work found it and from what I remember, it opens like 20 ports for listening (random sets or something) and also has something for what seems like a denial of service attack for windowsupdate.com...
SoBeLover
Explorer Babe Moderator
Moderator
Middletown, Connecticut
None
I have a firewall up...will that help? :)
dejello
College Station, TX
Couldn't hurt.. Actually I've got one up and running through a router too and haven't had any problems..
Campo
Elitus Explorus
White City, KS
99 XLT 4x4
Sorry it's taken me so long to reply..
But It does use port 135 (windows sharing)
It does start a DDOS (distributied denial of service) against WindowsUpdate randomly between the 16th and 31st of Jan thru Aug and anyday in Sep thru Dec.
It stops a required service called RPC(remote procedure call) and it will cause an XP system to reboot in 60sec. and since the service it dead it won't come back up.. on a 2000 system, since it is not required (just needed) the system will not reboot, but will start acting like a 486 and no network...
and it does alot of various nasty stuff..
just check out the specs on it at
http://www.trendmicro.com/vinfo/virusencyclo/default5.asp?VName=WORM_MSBLAST.A&VSect=T
