Weird Brake light issues | Ford Explorer - Ford Ranger Forums - Serious Explorations
protomind
94 Limited Edition
Brakes work great, however the light comes on. . . . it sucks. The problem is that whenever I wiggle the parking brake around (while it is fully up) I can make the brake light turn off. Is there some sort of switch or something that may be going bad?
Kyle0614
Greenville, NC
'95 XLT
it's called a brake relay switch ...if you have one...
protomind
94 Limited Edition
Am I asking the wrong way? Wrong forum?
wolfnutts
chester nh
91 nav ho. 96 5.0 4 dr
how much wiggle do you have ?? their are plastic bushing at the top of the brake arm maybe their worn out take a flashlight an peek up under your dash while you work pedal around
protomind
94 Limited Edition
This wiggle is on the emergency brake, is that where the bushings are?
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
protomind
94 Limited Edition
The in dash brake warning lights.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
protomind
94 Limited Edition
Would failure of this switch cause intermitant brake warning ligt to come on and off? Also possibly on occasion causing the abs light to come on?
Blacksheep Josh
Slinky+Escalator=Fun
Statesboro, GA
'01 Ford Ranger, RIP 93 X
my light in my dash used to come in, my fluid was low. make sure it's filled. dont' know why fluid would be related to e-brake, but it fixed it.
pvstansel
San Diego, CA
94 XLT
My dashboard brake light came on. While the brake fluid was not low, it was not full either. Added a splash of brake fluid and the light went off. This forum helps me out yet another time. Thank you.
BTW, I've also had to replace the brake relay switch a few times. On my explorer, I know it has failed when the brake lights just stay on all time.
I still have the ABS light which stays on 80% of the time. I'm thinking it is one of the front wheel sensors. Lower priority for me since I don't have snow and ice to deal with.
