Weird chirping noise PLEASE HELP!
Thewinedoc
Camp hill
2015 explorer XLT
Hey everyone!
Wish I could upload a video... I’ve had the beast In the shop twice and when I drove it home it did it again.
around 5 minutes into the drive I get a really loud chirping Squeaking noise that lasts about 2-5 minutes then goes away. It seems to be coming from the right bottom side of the engine, but no one knows where. I am beginning to think it’s a bearing, but it is LOUD!
have any of you ever had this? I’ll put it up on YouTube and share the link...
Join the Elite Explorers for $20. Gets rid of the ads!
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
How many miles and are you awd/4wd? The ptu will make similar noises when failing.
94Eddie
2010 Mountaineer Premier
When you say the right side do you mean the passenger or driver side?
Odrapnew
MN
2014 Explorer Sport
Belt or belt tensioner pulley bearing?
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
I'm going to guess it's on the passenger side since he says he notices it when driving.
peterk9
Staff member
Moderator
Callsign
VE3
Welcome to the Forum Thewinedoc.:wave:
Is it the same 2-5 minute interval regardless of the speed you're driving?
94Eddie
If it is the passenger side then I would lay odds it is a worn belt or accessory pulley causing the problem. I just replaced my belt a couple of months ago and it sounded like a bird chirping at times. One way to tell if it is the belt is to spray water on it while it is making the noise. If the water makes the sound go away then it is most likely the belt causing the sound.
Thewinedoc
Camp hill
2015 explorer XLT
They replaced my belt two weeks ago and it made it as I was leaving the lot. The worst part is that it only makes the noise when there is a load on it. Around 2500 rpms to 3000 rpms
Thewinedoc
Camp hill
2015 explorer XLT
So it’s a 2015 with 100,000 on it and it’s an xlt with 4wd. Thanks for your help!
Adrian Gitch
Paris, KY
2015 Explorer Limited
Was it a ford dealer where you got the belt replace? Also I think there's two different belts depending on what alternator you have. Could be a belt tensioner or idler pulley.
peterk9
Staff member
Moderator
Callsign
VE3
Thewinedoc
Camp hill
2015 explorer XLT
here! Tell me what you think it is guys?
Adrian Gitch
Paris, KY
Ya know that doesn't sound like the belt to me. Could be the tensioner/pulley bearing. Find someone you trust and have them put it in gear, keep pressure on the brake pedal and push the accelerator to put a load on it while you have the hood up and maybe you can narrow it down. Or, tell the dealer to diagnose it for you.
bigdude2468
2014 Explorer XT
long shot here. My son had a Chevy Cruze that would chirp. We thought it was the serpentine belt, changed it did nothing. The sound was weird in that we could not figure out exactly where it was coming from. I have a mechanics stethoscope and I listened everywhere without luck. Against my recommendations he changed the tensioner which did not fix it. Turned out a spark plug was loose. His Cruze has a cover that hides / shields the plugs. The spark plug wire was keeping the plug from getting any more loose so to speak but loose enough that a small amount of exhaust would leak. No codes which I thought it would throw. Noise would vary with temp, aluminum head expanding and contracting. Due to where the plugs are located its all but impossible to identify where the sound is coming from. We kept looking at belts, alternator, vacuum leak etc. One plug and a replacement wire and it was fixed.
Thewinedoc
Camp hill
2015 explorer XLT
Did it only do it for a little or a long time? Did the vehicle need to warm up and did it stop after a while???? That’s crazy!
Thewinedoc
Camp hill
2015 explorer XLT
So it does it after the car just gets warm. Usually 10 minutes. And does it constantly for 2 to 3 minutes straight then sporadically throughout a drive.
Pwerdbybeard
Northern California - Bay Area
2013 - Ford Ex Limited
I would suggest what the other post suggested and check your PTU but also check your transmission.. Mine made a similar sound until one day it felt like I lost power, come to find out my transmission was toast.. The PTU is designed to run the same oil for the "life of the vehicle" However, by poor design by Ford, its right next to the engine/exhaust and because of this, gets STUPID hot which causes the oil to clump up. When it does, there is actually less oil moving around, which was also my issue. New transmission and a PTU clean out, no more issues.
B Acting weird Stock 2011 - 2019 Ford Explorer Discussion 0
Bobs2018Explorer Weird "sticky" oily substance near A/C compressor? Stock 2011 - 2019 Ford Explorer Discussion 15
B 14 Explorer RPM Weird Issue Stock 2011 - 2019 Ford Explorer Discussion 7
B Weird noise coming from right front Stock 2011 - 2019 Ford Explorer Discussion 7
S Weird electronic issues Stock 2011 - 2019 Ford Explorer Discussion 11
Jon M Weird no start issue & slow MFT start up Stock 2011 - 2019 Ford Explorer Discussion 7
L Weird encounter when lock door using door handle Stock 2011 - 2019 Ford Explorer Discussion 0
R Weird Speedometer problem 2012 Base Explorer Stock 2011 - 2019 Ford Explorer Discussion 1
D Weird Squeak Stock 2011 - 2019 Ford Explorer Discussion 11
B Ghost in the Machine - Weird Noise from Brand New 2015 Explorer Limited Stock 2011 - 2019 Ford Explorer Discussion 11
M battery drained / wont jump weird stuff going on. help!! Stock 2011 - 2019 Ford Explorer Discussion 2
S Weird squeak coming from back of 14' XLT Stock 2011 - 2019 Ford Explorer Discussion 7
P Weird Noise. Speakers- Please help!! Stock 2011 - 2019 Ford Explorer Discussion 6
R Just noticed weird noise this morning Stock 2011 - 2019 Ford Explorer Discussion 2
O Steering feels weird but no power steering fault Stock 2011 - 2019 Ford Explorer Discussion 9
P Weird beeping Stock 2011 - 2019 Ford Explorer Discussion 22
D Weird Headlights Stock 2011 - 2019 Ford Explorer Discussion 6
W Weird piggyback harness found Stock 2011 - 2019 Ford Explorer Discussion 4
R weird symbol on phone display Stock 2011 - 2019 Ford Explorer Discussion 2
R Weird audio problem Stock 2011 - 2019 Ford Explorer Discussion 5
T Weird Issue with MyFord Touch Stock 2011 - 2019 Ford Explorer Discussion 17
J 2016 Explorer transmission ratting noise Stock 2011 - 2019 Ford Explorer Discussion 2
A 2012 Ford Explorer XLT Front Suspension Clunking Noise Stock 2011 - 2019 Ford Explorer Discussion 13
B Popping noise coming from engine Stock 2011 - 2019 Ford Explorer Discussion 5
S ‘13 Explorer rear grinding noise with any speed Stock 2011 - 2019 Ford Explorer Discussion 3
B Popping/grinding noise coming from under the front end when steering left or right Stock 2011 - 2019 Ford Explorer Discussion 4
F New member...ting/pop/click noise-front half shaft 2015 Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 10
M Exterior noise through HVAC system... Stock 2011 - 2019 Ford Explorer Discussion 1
K 2014 Explorer Passenger Side Noise Stock 2011 - 2019 Ford Explorer Discussion 1
M 2018 Ford Explorer XLT 3.5L. Right side engine bay whine/whistle noise Stock 2011 - 2019 Ford Explorer Discussion 13
R Guide to fixing rattling noise in upper 60 rear bench seat Stock 2011 - 2019 Ford Explorer Discussion 0
E Intermittent Noise When Making A Left Turn Stock 2011 - 2019 Ford Explorer Discussion 2
deewan Quick Question for exhaust noise Stock 2011 - 2019 Ford Explorer Discussion 8
C Tapping Noise Help Needed Stock 2011 - 2019 Ford Explorer Discussion 0
M Hello :) Ticking / Clicking noise heard when rotating steering wheel Stock 2011 - 2019 Ford Explorer Discussion 5
W ‘Ting’ noise while driving Stock 2011 - 2019 Ford Explorer Discussion 8
L 3000 RPM noise 2016 explorer 2.3l Limited Stock 2011 - 2019 Ford Explorer Discussion 4
E Engine squeaky noise Stock 2011 - 2019 Ford Explorer Discussion 11
K 2011 Banging noise in front, need help Stock 2011 - 2019 Ford Explorer Discussion 14
H 2015 explorer four cylinder eco boost ticking noise Stock 2011 - 2019 Ford Explorer Discussion 3
M 2013 Ford Explorer Dash Noise\Grinding-Not a blend door I think Stock 2011 - 2019 Ford Explorer Discussion 3
9 Right Rear Buffeting Noise? Stock 2011 - 2019 Ford Explorer Discussion 5
C Mystery Noise?? Stock 2011 - 2019 Ford Explorer Discussion 18
P ‘12 just serviced- noise on drive belt Stock 2011 - 2019 Ford Explorer Discussion 9
A 2012 XLT whirring noise Stock 2011 - 2019 Ford Explorer Discussion 5
M Random new noise in steering column Stock 2011 - 2019 Ford Explorer Discussion 2
D Grunting noise.... Stock 2011 - 2019 Ford Explorer Discussion 2
D Buzzing noise under dash when car is off Stock 2011 - 2019 Ford Explorer Discussion 7
expoman55 Interesting engine thumping Noise at 62k: Stock 2011 - 2019 Ford Explorer Discussion 24
E 17 Sport squeaky noise Stock 2011 - 2019 Ford Explorer Discussion 3
Similar threads
