- November 6, 2000
- 2018 EX Sport Concept
Have some REALLY weird electrical and starting issues with a 2007 ST 4.6L V8.
Ran fine, then had a brief episode a few days ago where the engine shut off when driving, but started up again. No problems for several days.
Today, after driving a bit and turning it off, get back in and it won't start.
When they key is turned, there is no fuel pump noise, no cranking, no starter click.
The weird part is, with the key turned on, the throttle clicks and clatters/rattles like it is rapidly opening/closing, or the relay is working.
It also sounds like one of the relays in the drivers side kick panel is clicking.
Sometimes the idiot lights on the gauge panel flash on when trying to turn the key to start it. The gas gauge appears to work. Sometimes the dome light goes on when turning the key on as well.
Battery shows 12.8 volts, terminals cleaned, connections at battery, starter and solenoid are good.
Vehicle also seems to have developed the stuck gear shifter issue, but I'm not sure if that's directly related to the starting issue or not. Manually releasing the shifter and putting it in Neutral doesn't change anything, it still won't start. Pushing it forward and holding it in Park doesn't change anything, nor does holding the park safety switch on the shifter. Thinking of replacing the shifter and park detect switch, perhaps even the ignition switch, but not sure if any of these are something that would cause the weird issues with it not starting.
Ford TSB 06-10-7 is about no starting with instrument cluster issues, perhaps a new cluster is a fix? Anyone done this?
ww2.justanswer.com/uploads/.../2011-10-30_211802_tsb06-10-07.pdf
Any help related to this issue appreciated.
