akbossman
- June 5, 2009
- Wasilla, Alaska - Igloo joke free zone
- 1991 Navajo LX
In April I put a new thermostat and water pump on my 91 Navajo 5 speed with 260K miles. Thursday I got on the throttle hard and it stuck so I pushed in the clutch and then quickly turned off and on the ignition. I stop at the store for 4 or 5 minutes and come out to loud hissing sound. I drive to the back of the parking lot and it is pouring anti freeze out under the truck pretty bad. I am only 6 miles from work so I try to baby it back and it over heats bad. (my bad) I let it cool add water and no leak. (OK bad water pump?) I let it run and every thing seems OK until I turn it off and the overflow tank that I had completely filled was boiling. I pulled the hose leading into the overflow tank off and super hot air came out from quite a while. When I drove it home it once again overheated and boiled the overflow tank. So I again figured bad water pump.On Monday I had to take a short trip that turned long and no problem except I have no heat????? Tonight i just pulled the fan and belt and turned the pump and it seems to move water from the noise I hear.
Do you think the pump is bad? I hate to change it if it is something else. The large amount of water still is weird. I guess I pull it of in the AM. Thanks.
