- June 3, 2003
- Austin, TX
- OBD-1 Kenobi
ok, this is weird. Last saturday, i was driving to edmond from mustang, about a 40 minute drive, and on the way, i notice Blue start to sputter, and want to loose engine power (the electrical stuff, headlights, stereo, were fine, no affection) and an iratic idle situation. I had to pull over on the side of the interstate (65 MPH, i almost died), and Blue died. well, i got him started again, but with a really bad idle and even higher in the power band, it was irratic. i would press the gas pedal, and nothing would happen.. well, i finally got back on the road, and was doin 55 at 3200 RPM...the computer would shift into overdirve (or maybe even 4th). and the check engine light was on during all this. Heres the weird thing: when it was sputtering, the check engine light was "sputtering" too. like, it didnt just come on and off like a light switch, rather, it would flicker in sequence with the fuel pump relay that was continuosly engaging/diengaging. so the MIL and the fuel pump relay (could have been the ECM relay as well, i dont know) were "synched" together, because they were both acting up together. anyway, i get to edmond, and when ever i would slow down, the truck would sputter, and die. then after being on the shoulder of road in edmond for about 10 minutes, i start it, and it runs perfectly, no problems. then i get near my apartments, it starts cutting out again, like just really really irratic RPMS. well, i finally get to my parking lot, and kill it.
Sunday: i call autozone to see if the can check ANYTHING, and so i start driving it over there. i start the truck, no problem. then i get about 500 ft down the road, it starts doin it again. i pulled over into a parking lot, and call my dad to bring the trailer. when he gets here, of course, it starts fine, and drives up on the trailer, no problem
Later that same afternoon.....
we get to my mechanics shop, and i drop the truck off. well, its running just fine on the trailer. i park it and call my mechianc, and tell him what all i told yall. anyway, i call him today, and this is what i found out
after the phone call...
it acted up on him monday, so at least he saw and felt the problem. he was having trouble keeping it running trying to pull some codes. well, he ran a fuel pressure test, all his electronic diagnostic tests, and pulls two codes. a 290 something code, and a 130 something code. well, come to find out,t he codes he got doesnt exist , even with verification from ford. THE CODES THE COMPTER GAVE HIM WERE FALSE CODES, DIDNT EXIST! ok, i thought, thats wierd. well, after running all of his diagnostics, the truck has been running fine since. hes driving it on three 20 mile trips, with no problems.
so, here is my question: what could be causing all of this, cause my mechanic didnt technically find or correct the problem. it 'fixed itself' i dont want to be driving the truck, and have it 'un fix its self' thanks guys for your help!
