yugotprblms
- February 19, 2014
- 2000 Mountaineer
Hello all,
I am having a fairly odd issue, and I have not found any other posts with similar symptoms. Essentially, the turn signal works intermittently. It may flash normally for quite a while, and then it will just stay on. Or it may flash only a few times and then stay on, or it may just come on and stay on when I use the signal. I have not tried turning the hazards on to see if they behave the same way yet.
Would it be correct to think it would be an issue with the flasher? My line of thinking is that the switch or cables in the steering column may not be the issue as it happens with indicating a left OR right turn. It behaves the same for each side.
Thanks!
Thanks!
