atistang
- December 17, 2007
- Ohio
- 94 XLT
Bought warn hubs and conversion kits, set me back 280 bux:thumbdwn:
anyways when i went to install them i noticed the paper that came with them showed a three piece thrust washer on the axles. The thing is when i pulled mine apart all i have is one steel washer. the paper showed two plastic ones in front of the steel. I noticed that the axle seemed to have a little play. I went ahead and put it back together as i needed my 4wd last night with the 3 foot snow drifts. Everything worked but it seemed a bit noisy
So is there suppose to be two plastic washers in front of the steel? And can you get them at any parts stores? Seems like just that steel one will beat up the end of my spindle.
