Westin Brush/Grill Guard install on gen 1 explorer | Ford Explorer - Ford Ranger Forums - Serious Explorations
n8ron
Denver
1994 Explorer XLT
I'm looking for any info/pics of what the brackets that mount to the frame on a Westin grill guard look like. I bought a grill guard on Craigslist w/o any brackets. I can make my own brackets, no problem, but before I do so I wanted to try and find out what the actual brackets look like just so I'm not going back and forth trying to make some fit. If anyone out there as any pics on any first gen brush/grill guard brackets installed or not I would greatly appreciate it. Thanks
Jason94sport
FL
04 EB V8
Don't have pics, but the ones I had on a old X I had were basically flat L shaped. They bolted to the bottom of the guard, went under the front bumper & then back around to the frame rails. They laid flat against the frame rails & then you drilled 1 or 2 holes using the bracket as a template into the frame rails & secured it with 2 more bolts.
n8ron
Denver
1994 Explorer XLT
Thanks for the info Jason. Do you remember if the brackets sat flush with the bottom of the closed frame or did they stand off below a few inches?
Jason94sport
FL
04 EB V8
They laid flat against the side. I had a few different guards, but they basically bolted in the same way. Some had 2 connection points, on the side & the bottom. But they all laid flat against the frame rails.
I had a shop weld the brackets in place as well.
