What can leak on transmission? | Ford Explorer Forums - Serious Explorations
  • Explorer Forum license plate frames are available 2 for $12, or 4 for $17. For photos and more details CLICK HERE
ponkotsu
Colorado Springs, CO
2005 Lincoln Aviator
Got the tranny out of my Aviator. That's 10 hours of my life that are gone! Symptoms it had: Noisy torque converter, converter not locking up code, leaking fluid. I verified that the rebuilder did indeed rebuild it. It has new bronze servo bore sleeves, so I will assume he replaced the rest of the internals. I can't see any obvious signs of leaking, but I had a pretty good amount of fluid sprayed all under the truck. Torque converter seal would be the obvious root cause, but the inside of the bell housing looked clean. I made quite a mess getting it out because the over flow tube dripped, so I can't say for sure what areas were wet before I removed it.
Inside of the Tcase flange had a small amount of dirty fluid in it, so I should replace those seals, but I was seeing clean ATF fluid leaking, so I don't think the tcase was the main leak.
From what I can see there are really only a couple places that can leak ATF: Torque converter sleeve, pan, rear seal, speed sensors, servo bore caps.
Seems like tranny leaks are hard to track down, just like a roof leak. The stuff runs everywhere, especially with the air turbulence underneath.
