gsoexplorer
- October 17, 2016
- Bucks County, Pennsylvania
- 2000 Explorer XLT
Hi,
In an effort to try to take every step I can to prolong my SOHC timing chains/guides, I have been cranking the engine with the gas pedal to the floor when the engine is cold. Occasionally after doing this it is hard to start and stumbles. Today it look about an hour after the initial cranking to get the truck going. I'm not sure what I did, but it would just crank and crank. I threw my battery on a charger, I disconnected the negative cable for 15 minutes, all with no change. I finally put the gas pedal to the floor and cranked it again and that got it to turnover. Does anyone have any thoughts on this? I'm now hesitant to continue trying to get the oil pressure up by using this technique.
Thank you
Thank you
