N2FORD
- January 20, 2002
- Kingston,TN
- 2001 Sport Trac 4wd
Back up camera is installed. Really liking it.
Here is with the color set to match the dash:
With where I installed it, surprisingly, it even works well with the tailgate down.
The only real set back was that I messed up the RCA plug when feeding the camera wiring into the interior and had to splice in a new one.
I have the wiring kit that came with my crutchfield head unit if anyone needs it. My used ST already had an after market radio and someone before me cut the wires and removed the amp and sub, so I had to splice into the vehicle wiring versus into an adapter that plugs into the factory wiring.
Can you tell us more about the unit you installed? Does it PROPERLY fitup into the OEM dash opening? I'm looking to replace the 02 Ford OEM radio/tape deck/CD player in my Wises S/T but I would like a unit that fits into the existing space using the Ford mounting system. I dont see where you mounted the camera. If you had to run the wiring again would you do it differently?
