bcboy4ca
- April 26, 2009
- Chilliwack, BC
- '98 XLT
I recently had the ABS light come on and have been having a weird growl/grind/hum coming from the front end so I decided to replace the front hub assemblies.
Once I got the truck into the garage and on 4 jack stands I figured why just do the wheel hubs, may as well do some maintenance so I did the following today...
1) Front Wheel Hub Assemblies
2) Drained Transfer Case - Filled with B&M Synthetic Trick Shift ATF
3) Drained Rear Diff - Filled with Royal Purple Synthetic 75w140 Gear Oil
4) Dropped Rear Driveshaft and greased slip shaft (no more clunk
5) New Energy Suspension Front End Links (passenger side was missing)
6) Drained Power Steering Fluid - Filled with B&M Synthetic Trick Shift ATF
7) Replaced all four shocks with KYB GR-2's - Excellent ride now
The only real PITA was replacing the rear shocks, 2hrs to remove the old ones and 15 minutes to put the new ones on
. Other than that is was an enjoyable day in the garage and the truck drives SO much better now.
So what did you do this weekend?
