Lynchy,
Here's a pic of my current setup with the CB antenna in the factory AM/FM location. It's a Firestik II 3 foot with tunable tip and a spring stud base.
Here's a close up of the base:
I routed the cable through the same place where the AM FM cable goes, then behind the glovebox, then to the cb radio (cobra 75wxst), which is here:
I like it because its compact, the radio, all the tuning, the speaker, etc are in that handheld part. Plus, when you don't want to use it, you can disconnect it from the port I made in the console (parts come with the radio) and put the handset away somewhere:
There is a little box that goes inside the console and that's where you hook up the antenna cable and also the power wires. I was able to tap into an unused wire harness in there that has continuous 12v and you can ground the negative wire to the metal plate under the console...works great:
The only drawback with the way I have the antenna set up is that it's taller than the factory radio antenna and it's heavier, so doing the bracketing in the fender is tricky (i tried re-using the stock antenna bracket and it still leans to the side more than I would like and is not sturdy enough in my opinion). Plus if you need to work on it you have to take off the front passenger side wheel and the mud guard in the fender and then reach up in there to work on it.
So, I'm going to move the antenna to the back and put my factory am/fm setup back on. This is the bracket I am going to use:
http://www.firestik.com/CatalogFrame.htm
and install it here:
Main thing is to make sure you get a really good ground between the bracket and body otherwise your power output will suck and you'll potentially damage your radio. Look at the tech section on firestik.com if you are like me and didn't know anything about how all this stuff works until a month ago
