saxon
- March 30, 2006
- seattle, wa
- '91 & '93 EB, 4WD, 4-door
What does the stock VB boost valve do? (+ how to yank a stuck one)
Background: rebuilding valve body out of 1991 4WD A4LD. Obvious things found thus far: OD band adjusted 2.0 turns for single wrap, should have been 3.5 turns for double wrap. Also, TCC solenoid was defective.
New issue: The stock boost valve is the only bore in the VB that I have not been able to pull out. Since I bought the Sonnax boost valve update I can ruin the stock valve. I'm planning to drill a small hole in the stock boost valve, stick a screw in it, and yank it out that way (the same way that Glacier991 removed the stock boost valve from his oval boost valve bore; http://www.explorerforum.com/forums/showpost.php?p=1269705&postcount=52). Wonder if my boost valve bore is oval, too...? Is that common?
btw, what does the boost valve do anyway? I haven't seen that info. anywhere.
