What is causing my sport to vibrate? | Ford Explorer - Ford Ranger Forums - Serious Explorations
njkev7
Jersey City NJ
At startup the truck is fine. When I drive and come to a stop. It starts to vibrate lightly but enough to feel. I asked my mechanic and he say Ford Trucks are like that. My question is does everyone have a vibrating truck and what could be causing it. Also, the idle is a bit jumpy, looks to go between 500 to 1000 rpms. I just did the tune up and ran fuel injector cleaner with premium gas. All filters were replaced and pcv was replaced also. It’s a 99 sport 4.0 SOHC with no check engine light.
Spdrcer34
Bremerton, WA
1992 Explorer XL
A bad IAC, or Idle Control Valve can cause that. And that is the first place I'd look.
There are a few threads here to look at. They cover everything from their Location, to cleaning them. And their Replacement.
Just make sure you search for write-ups that cover your particular engine. As their locations are very different.
Ryan
alohamonte
Glendale, AZ
1998 Explorer 4.0 4x4
i had similar problems with my X and it turnd out to be dirty injectors. i regularly ran sea-foam through the pcv and gas tank, but the injectors were heavily soiled. runs perfect now.
njkev7
Jersey City NJ
How effective would sea foam be if i just ran it though the gas and not in the PCV.
njkev7
Jersey City NJ
Ok, so I replace the Air Idle Control Valve and it's still vibrates. I been running super and a few bottles of injector cleaner. But its still vibrating. I replaced the plugs and wires with motorcraft plugs and napa belden wires. What could be causing this. Sometimes when I drive if I give gas it idles down than goes up.
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
could be an intake gasket leak? or vaccuum right?
Lower intake manifold gaskets would be where I place my money. Common problem that's getting more and more common as these vehicles age, and it gets worse in cold weather (like we start seeing in the northern latitudes this time of year).
-Joe
njkev7
Jersey City NJ
What can I do to make sure thats it. Also, I have the tools and the time, how do I replace that. Any step by step diagrams?
gijoecam
Village Idiot
Trenton, MI
Search and yee shall find. There is a how-to with pictures on the site, and TONS of posts on the issue.
