What is my towing capacity 02 3.73 4.0l | Ford Explorer Forums - Serious Explorations
steve63933
'02 XLT 4X4 4.0L
Getting ready to buy me a camper and I am wondering what my towing capacity is.
Here are the specs:
2002 4.0L Auto tranny 3.73 Gears (D4) Factory 2" hitch with factory trailer brake hook up.
I no there are some variables as far as how much weight is in the vehicle while towing.
Just looking for a good round about weight.
I did a search but keep finding different numbers.
Thanks
I know it is in the manual, but the wife has the Mountaineer today. If you do not have one to check out, I will get to it or hopefully someone else will chime in sooner.
Tow Rig forum 'Tis in the stickies
The chart only went up to 2001 and I done a few searches and came up conflicting numbers.
I went to the ford fleet sight to look at the owners manual (which I should have done in the first place) it stated
Maximum GCWR 10,000lbs
Trailer weight range 0-5380lbs.
With anything over 3500lbs needing a weight distribution hitch. Which I have.
These numbers seem very high too me.
He is the info for towing straight from my manual:
Engine: 4.0L SOHC
Rear axle ratio: 3.73 LS
Maximum GCWR-kg (lbs) 4 645 (10 240)
Trailer weight range-kg (lbs) (0-Maximum) 0-2 694 (0-5 940)
