  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
What is this I found in my air filter box?
gday
Loomis, California
2013 Explorer Sport +402A
Callsign
VK2XOC
My dealer normally changes the air filter in my 2013 explorer sport when needed however there was a mix up last week so I decided to do it myself. I opened the air box, removed the old filter only to find some large piece of foam/rubber floating around and partially blocking the intake opening. Its approx. 6"x2"x1/8". I can't figure where it came from or where it belongs. Right now its in my kitchen and while it could be my imagination, things seem to run much better.
Any ideas what this is? Curiosity is getting the better of me ;-) Cheers!
-mick
974X4BLACKSPORT
Location
FL
hudson
BLACK 1997 SPORT 4 BY 4
Some filters (mostly equipment) have a foam "pre-filter" on top of the actual filter element to stop the bulk large objects like leaves/moss from getting stuck in the filter.
gday
Loomis, California
Callsign
VK2XOC
This thing is not porous nor anything close to the size of the actual filter or the air box opening (which is oval).
-mick
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
-mick
It's likely something that fell in during the last change. It's no wonder the vehicle seems to be running better now that it is getting the amount of air it was designed for.
Keep it and show it to the dealer next time.
974X4BLACKSPORT
Location
FL
hudson
SO. this thing was found AFTER the dealer had installed the last filter?:crazy:
gday
Loomis, California
Callsign
VK2XOC
Well yes and no. While I've changed brakes, batteries and some other things, I've always had the dealer change the air filter until this last time. What happened is that my car was in for the "Works" oil change. They pulled the old filter and told me it needed changing in a phone call - I said change it but there was a miss communication along the lines and they didn't. So I did a week later after I ordered the FORD OEM filter from amazon and that's when I found this thing floating around. It sort of feels like sound insulation but I can't find any place it would have come from so maybe its just extraneous crap. Just looks like some sort of car part if that makes sense.
-mick
JAPeterson
Gypsum, Co
2016 XLT
At times you will never know what you might find in a air box.
I found a half bag of miniature marshmallows in the air box of my diesel truck one time. All I could figure was that somewhere along the road I had ran over the bag or it had blown out of a vehicle and I caught it just right where the air intake was located at.
The only other explanation would be that someone was playing a joke on me.
MtnCar
2013 Explorer Sport
It came from the back side of the grill. I noticed it when I had the grill/bumper partially removed while doing a HID projector retrofit. In my case the material, both pieces were partially attached to the grill just inside of the air intake opening. I'm sure if I did not notice it eventually they would have either blocked or got sucked in the the intake as they continued to come unglued from the grill. I removed them as I did not see an obvious purpose the them in the first place.
FordSVTGuy
New Hanover, PA
2017 Ford Explorer XLT
I just changed the air filter on my MKC and found like 10 acorns an some shells at the bottom of the air filter housing...caught me by surprise :eek:
A Oil Found In Air Filter Stock 2011 - 2019 Ford Explorer Discussion 101
D Found the Explorer.... but its a Buy Back? Stock 2011 - 2019 Ford Explorer Discussion 49
C 2011 explorer key not found Stock 2011 - 2019 Ford Explorer Discussion 11
Daheim111 What is this ? Found it in the engine compartment near the fans... Stock 2011 - 2019 Ford Explorer Discussion 5
1 Found cool technical information and development of 2.3L Ecoboost Stock 2011 - 2019 Ford Explorer Discussion 0
1 Oil leak found on the top of the engine? Stock 2011 - 2019 Ford Explorer Discussion 1
K Found out the hard way the X has a hard hide Stock 2011 - 2019 Ford Explorer Discussion 3
G Just got back from Oil Change and found oil on floor Stock 2011 - 2019 Ford Explorer Discussion 26
C Found a loose bolt Stock 2011 - 2019 Ford Explorer Discussion 6
W Weird piggyback harness found Stock 2011 - 2019 Ford Explorer Discussion 4
R Key not found! Your car will now annoy you in public! Stock 2011 - 2019 Ford Explorer Discussion 2
W Found a 4wd Explorer - "DEMO" Stock 2011 - 2019 Ford Explorer Discussion 12
L 2013 XLT air condition problems Stock 2011 - 2019 Ford Explorer Discussion 2
N Ambient Air Temp Sensor Replacement 2016+ Stock 2011 - 2019 Ford Explorer Discussion 1
B 2011 Explorer Terrain Management System Fault and Service Advanced Trac. No air blowing at all. Stock 2011 - 2019 Ford Explorer Discussion 1
E Air Conditioner Charged and Compressor Spins, but no cooling Stock 2011 - 2019 Ford Explorer Discussion 3
F 2015 Explorer Limited Air Bag Light Stock 2011 - 2019 Ford Explorer Discussion 0
G Air shutter wiring harness Stock 2011 - 2019 Ford Explorer Discussion 2
D Air Conditioning Died--Suggestions? Stock 2011 - 2019 Ford Explorer Discussion 2
S Solved Ambient Air Temperature Location Stock 2011 - 2019 Ford Explorer Discussion 1
T Air Conditioner Problems Stock 2011 - 2019 Ford Explorer Discussion 4
edwx Does my 2017 Explorer have a cabin air filter? Stock 2011 - 2019 Ford Explorer Discussion 6
R Hot air out vents when accelerating Stock 2011 - 2019 Ford Explorer Discussion 3
S ambient air temp sensor Stock 2011 - 2019 Ford Explorer Discussion 0
R 2014 front windshield defogger is forced air only? Stock 2011 - 2019 Ford Explorer Discussion 2
M Black carbon on engine air filter every 4 months Stock 2011 - 2019 Ford Explorer Discussion 7
T 2015 Explorer Air, ambient lighting, outside temp gauge stopped working Stock 2011 - 2019 Ford Explorer Discussion 4
J 2011 Air conditioner issues. Stock 2011 - 2019 Ford Explorer Discussion 0
J 2017 XLT cabin air filter Stock 2011 - 2019 Ford Explorer Discussion 7
E fan speed fluctuates on 2015 ford explorer air conditioning Stock 2011 - 2019 Ford Explorer Discussion 6
Z Air filter element? Stock 2011 - 2019 Ford Explorer Discussion 19
B Hole in Blend Air Door on drivers side 2011 XLT Stock 2011 - 2019 Ford Explorer Discussion 1
B 2016 Air Conditioning Subframe Stock 2011 - 2019 Ford Explorer Discussion 6
S Bigger tires more or less air? Stock 2011 - 2019 Ford Explorer Discussion 6
Z Engine Air Filter Replacement (How To Video Added) Stock 2011 - 2019 Ford Explorer Discussion 3
A Possible to replace/reprogam interface in 2018 Explorer Sport to get air direction buttons? Stock 2011 - 2019 Ford Explorer Discussion 2
K Getting cold air on drivers side floorboard - 2016 xlt Stock 2011 - 2019 Ford Explorer Discussion 0
J K&N air filter question Stock 2011 - 2019 Ford Explorer Discussion 21
Y 2013 Explorer Sport rear air not working Stock 2011 - 2019 Ford Explorer Discussion 4
M 2017 how to get air out coolant system Stock 2011 - 2019 Ford Explorer Discussion 14
C Explorer Sport turbo air scoop heat shielding Stock 2011 - 2019 Ford Explorer Discussion 1
B normal to have water/oil in air intake duct/3.5 ecoboost? Stock 2011 - 2019 Ford Explorer Discussion 8
T Air fan speed / Voice Button Question Stock 2011 - 2019 Ford Explorer Discussion 2
B No Air conditioner Stock 2011 - 2019 Ford Explorer Discussion 4
G 2014 Explorer only blows hot air from defroster Stock 2011 - 2019 Ford Explorer Discussion 1
A Loose rear 2nd and 3rd row air vents Stock 2011 - 2019 Ford Explorer Discussion 5
R Explorer Rear Air Vents Stock 2011 - 2019 Ford Explorer Discussion 7
D Humming from Glove Box When Changing Air Controls Stock 2011 - 2019 Ford Explorer Discussion 5
F Cold air intake box Stock 2011 - 2019 Ford Explorer Discussion 28
R Air conditioning and oil alert at the same time. Stock 2011 - 2019 Ford Explorer Discussion 4
Similar threads
