What is this? | Ford Explorer Forums - Serious Explorations
What is this?
Alanslinky
Milford, CT
ex- 94 Eddie Bauer
What is this for? I have a hose missing off of it and cant find it. Is it important?
Its the charcoal canister for the evap system. If I remember correctly one hose comes from the gas tank (vent).. The other hose goes from there to the throttle body (small hose at the bottom of the TB)..
The hose to the throttle body has a valve between the TB and the canister... Thats the evap purge valve.. It makes sure your not always putting the fumes into the engine (I can't remember when it opens)..
~Mark
mines the same and has never had anything attached to it. and it is not that important
if you have visual inspections that are part of emisions testing they will problably fail you with that line disconnected.. As for tailpipe emisions, I don't think it will hurt any.
~Mark
Yea it connects to the bottom of the TB like maniak said. At any position but idle is when it opens to allow fumes built up from the gas tank to flow into the TB and be burned in the engine instead of escaping into the atmosphere.
Thanks everyone. Yeah in CT all it is for emisions is tailpipe so I think I'll just leave it disconnected and not worry about it.
I would hook it up personally, what likely happened is the canister purge valve likely went south, so this sucker got removed.
I would get a good canister purge valve, install it with the hose from the bottom of the throttle body then to the inlet of your charcoal canister...which vents the fumes from your gas tank into the upper intake manifold
currently the fumes in your gas tank are venting just into the canister, not into the engine to be burned.
Up to you, but I like to keep my emissions stuff in place because it was designed to be there. Do you currently have a check engine light?
Is the hose on the bottom of your throttle body open to atmosphere?
Is there a canister purge valve just hanging on the wiring harness not hooked up?
All things to look into IMO
410, is it possible this could in any way affect mileage? Here's my thought process (hope you can follow it), if there are gasoline fumes going to atmosphere, and fumes are flammable, couldn't this affect mileage? I know it won't be a huge difference, but it could?
Any evaporative emissions leak will affect fuel economy, yes. A leak between the purge valve and intake will be a very very small difference. Any other leak in the system will allow fuel loss when the engine isn't running. Your gas dries up like a glass of vodak left out in the sun.
Also you will have a vacuum leak if the hose going to you TB isnt connected or capped off.
I didn't even notice the connector underneath the TB. I've got some extra parts around since I ripped out my AC at the same time, and wasnt sure what went with that and what didn't, so I'll see if I can find this purge valve in the pile of "extras" in the trunk.
ouch pile of "extra's" I know that feeling LOL
wierd mines in a completely different spot on the drivers aide of the radiator.
Mine from the factory was also on the radiator core support (1992 X)
~Mark
Yea thats where mine is also. 91-92 are different the 93-94. Even the wiring harnesses are different.
