Spartan
- September 24, 2009
- Sun Prairie WI
- 1996 XLT, 5.0 2WD
1996 Explorer XLT, RWD, and the 5.0 motor. Automatic transmission.
My Axle code is D4, which I know to be a 3.73 limited slip. I have to replace an axle shaft bearing and seal, as well as the pinion seal and likely the outer bearing. I'm trying to order parts, but don't want to run into the situation where I order the wrong seals/bearings.
Do i have a 31 spline or 28 spline axle?
If you guys have any part numbers that might be applicable to that rear end and Explorer, please let me know.
