Postal_Dave
- July 14, 2021
- Greenville, SC
- 1996, Explorer, 4.0
Turdle: I've replaced the ignition switch and verified it's not that by turning the key to On, then using the solenoid under the hood and a heavy duty screw driver to jump leads and make the starter engage. I still got spark at the end but nothing while cranking.
Danny: I've checked the throttle position sensor and back probed the voltage, (I was hoping it was this) however, the voltage coming from the sensor is correct for starting.
5OHHH: I have the basic flat keys. There isn't a chip reader in the keys. Also, the sensors I've changed out I've replace with Motorcraft parts or other top rated parts for Fords.
Jisumo: I replaced the CKP with a Dorman CKP. I bench tested it and I back probed it. It was creating 5 volts A/C when cranking. I will say that I'm temped to buy another one to try because it's one of the only things it could reasonably be.
BenDT: I inspected the wire, made sure I had continuity to the ECM harness and made sure it wasn't grounding out.
Joney and Nate: I replaced my coil pack with a motorcraft coil pack.
Runnin'OnEmpty: I pulled the RFI plug and checked all the wires to the coilpack connector, no signs of the wires grounding out. 12 volts is getting to the coil.
I'm going to work on this thing just a couple of more days, then it's off to the junk yard if it doesn't fire up.
Thnaks guys,
Dave
Thnaks guys,
Dave
