92 5 oh
- March 2, 2006
- VA BEACH, VA
- 87 RANGER
Hello, I've been looking around for a while and was wondering what size the trans cooling lines are on an A4LD? Are they 5/16" or 3/8" ???
One more question, can someone tell me which line is the feed to the radiator, then the aux cooler and back to the trans?
Oh yeah...one more thing lol
I have a mechanical temp gauge, and was thinking about installing it in the feed line on the trans, before the coolers so i could get worse case senario. I was thinking about getting a T adapter and splice it in the line, then put the sending unit in the T. Would this be accurate enought, I mean would fluid surround the entire sending unit? I wouldn't want any air bubbles.
Here's a little background info, I have an 87 ranger with an A4LD and just got it rebuilt. The cooling lines were kinked so i'm going to replace them so i've got a lot of options from here. What I would like to do is run 24" piece of line off the trans with a compression fitting/coupler (incase i have to remove the trans again), run the line to the radiator - with a temp gauge inline - then to an aux cooler, and back to the trans.
Hows this sound? I think it will work.
Thanks
steve
:exp: <--haha thats cool
Thanks
steve
