What size is the brake bleeder screw on my 99 mounty?
IowaBob
Location
Iowa
Cedar Rapids
1999 Mountaineer 5.0 AWD
Went to change my brakes on the mounty and used a 3/8, it stripped and rounded the bleeder screw!!!! Now its a real SOB of a job as I have to get the rounded screw off one caliper. The other 3 are really rusty. Is it a 10MM?
9 tube size for brake bleeder fitting Stock 1995 - 2001 Explorers 2
G brake bleeder size? Stock 1995 - 2001 Explorers 5
S Front Brake Bleeder Screw size? Stock 1995 - 2001 Explorers 6
D Blown 97 Steel Brake Line… (size question) Stock 1995 - 2001 Explorers 6
J Brake Hardline over Diff - fitting size Stock 1995 - 2001 Explorers 1
G What size brake lines and fittings? Stock 1995 - 2001 Explorers 5
gmanpaint Anybody know the correct size (T&P) of brake lines at the ABS pump? Stock 1995 - 2001 Explorers 5
A What size is the metal brake line for the rear? Stock 1995 - 2001 Explorers 3
D rear brake line size Stock 1995 - 2001 Explorers 1
jlsparky7 Disc brake size....... Stock 1995 - 2001 Explorers 3
R Is trans line fitting same size as brake line fitting? Stock 1995 - 2001 Explorers 2
quiksilverdh Replacing rear brake line... anyone know the size I need? Stock 1995 - 2001 Explorers 0
A EGR Valve to Upper Intake Bolt Size and Thread Pitch Stock 1995 - 2001 Explorers 2
D what size bolt is holding the camshaft synchro in place Stock 1995 - 2001 Explorers 3
E Fuel filter / fuel line size for disconnect Stock 1995 - 2001 Explorers 15
2 After Market Wheel Size Question Stock 1995 - 2001 Explorers 14
E I’m New Here & have Tire size questions Stock 1995 - 2001 Explorers 6
H 1995 Explorer Stock 4-door XLT Max Wheel/Tire Size Stock 1995 - 2001 Explorers 1
G 99 4L SOHC Xlt Exhaust pipe size? Stock 1995 - 2001 Explorers 1
G But size on front hub. Stock 1995 - 2001 Explorers 4
M Thread Size For EGR Port on Exhaust Manifold Stock 1995 - 2001 Explorers 1
L 2nd Gen radio size... Stock 1995 - 2001 Explorers 4
J What Battery size do I need? Stock 1995 - 2001 Explorers 10
R Key won't turn ignition after trying new uncut key for size Stock 1995 - 2001 Explorers 2
G iac bolt size Stock 1995 - 2001 Explorers 1
Craigerz Speedo Gear Size Stock 1995 - 2001 Explorers 2
P Torx Size Stock 1995 - 2001 Explorers 2
Craigerz Stock 98 5.0 Exhaust Size Stock 1995 - 2001 Explorers 4
F Fan Clutch Nut Size? Stock 1995 - 2001 Explorers 0
K calipper size Stock 1995 - 2001 Explorers 5
C 1997 AWD Front Hub Bolt Size and/or Part Number Stock 1995 - 2001 Explorers 0
W Spare Tire Removal Kit Size Stock 1995 - 2001 Explorers 1
2 Battery cable size? Stock 1995 - 2001 Explorers 2
M 1998 Eddie Bauer Rim Size Question? Stock 1995 - 2001 Explorers 9
1 Wrench size for 5.0 EGR tube? Stock 1995 - 2001 Explorers 9
G Correct Radiator Size for 2001 Explorer Sport 4.0? 1" or 2"? Stock 1995 - 2001 Explorers 8
G Stabilizer bar size question Stock 1995 - 2001 Explorers 4
stretchman Last year for manual transmission full size explorer Stock 1995 - 2001 Explorers 4
J Bumper fog light size 01 Stock 1995 - 2001 Explorers 1
H "Not another tire size and type thread!" I'm sorry but plz hear and help me out. Stock 1995 - 2001 Explorers 5
B 3rd tail light: Resistor size? Stock 1995 - 2001 Explorers 5
1 Leaf Spring Center Pin/Bolt Size Stock 1995 - 2001 Explorers 1
R OEM Tire Size Replacement Stock 1995 - 2001 Explorers 4
P Wiper blade size: 18 or 20? Stock 1995 - 2001 Explorers 19
T 5.0 Valve Cover Fastener size? Stock 1995 - 2001 Explorers 2
B What is the bushing size on the 5.0 rwd models?? Stock 1995 - 2001 Explorers 15
C Fuel Pump Selection and Wheelbase Size Stock 1995 - 2001 Explorers 2
S Grill/brush Guard size specs? Stock 1995 - 2001 Explorers 4
C 03 Sport XLT 4.0 sohc Muffler size? Stock 1995 - 2001 Explorers 2
A stock exhaust pipe size Stock 1995 - 2001 Explorers 0
Similar threads
