What triggers "Door ajar" light ?
Explorer_PL
Rockland County, NY
06EB V8
Hi -
Friend's 2003 XLT v8 has door ajar light. Everything is closed, there are no switches on the door jams. What controls that ?
Thanks
XploX
17 All-Terrain
If the doors are closed, two things can cause this. First is the switch on the latch. Second, and I've never seen it personally, is the wire harness in the door jamb has broken wires. Check the wire harness... free, or change the bad switch... a bit costly.
Explorer_PL
Rockland County, NY
06EB V8
Thanks, I think I know now where they are now.
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Explorer_PL
Rockland County, NY
06EB V8
Thank you both. I just watched it. I did not realize the switch is internal, not like old style push switch that you could see.
