What would cause codes 172,173,176,177 | Ford Explorer - Ford Ranger Forums - Serious Explorations
94ranger330
Greene County GA
94 4.0 RANGER 4X4
My ranger is running really rough, It is throwing the codes mentioned wich are both side lean and rich but what could cause it. I have replaced o2 sensors, maf, spark plug wires and plugs, air filter. Please help.
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
Do you get equivalent codes (136, 137, 172, 173) from the KOER test or do you get a different combination? Have you checked fuel pressure? Gas in the vacuum line to the fuel pressure regulator (FPR)? Any indications from the old spark plugs if it's running rich, lean, or what? Does the condition of the exhaust indicate rich or lean condition?
94ranger330
Greene County GA
94 4.0 RANGER 4X4
I get no KOER codes except 111 but the check engine light comes on from time to time.
MrShorty
Spanish Fork, UT
That suggests that the fault is intermittent. If you clear the CM codes and test drive until the CEL comes on, do you always get the same 4 codes, or different combinations? Any consistency to when the CEL comes on?
