ExplorerJimbo
- September 11, 2004
- Knoxville, TN
- 01 Explorer XLT
I have a clarke 131 arc welder 120v and I cant seem to find the right welding rod. anyone able to help?
heres the info on it:
Operates from standard 110V circuit.
Variable amerage control for accurate welding power control.
Includes hand held face shield and chipping hammer.
Automatic thermal safety switch prevents overload.
Weld all carbon steel.
Uses 1/16'' or 5/64'' electrodes.
Simple to operate and portable.
Weight: 34 lbs
Working Range Amps: 40 - 100
Amps Peek: 130
Circuit Breaker Recommended: 25 amps
Input voltage / phase: 110 / single
Electrodes: 1/16'' & 5/64"
Heat Settings: Variable
Duty Cycle: 30% at max output
Max Metal Thickness: 1/4"'
10/2 - Year Limited Welder Warranty
Weight: 34 lbs
Amps Peek: 130
