dent
- March 24, 2004
- toronto
- 2013 Explorer Limited
Just wanted to pass this along.
I just finished replacing the rear wheel bearing on a '13. what a serious pain!!!
once you get everything apart and it's time to take the hub assembly off the knuckle, good luck if you're in a cold climate where they use salt.
thing is corroded bad and almost fused on. it's dissimilar metals so it's going to seize bad.
tried that fancy hub removal tool, not luck
tried using an air hammer/ chisel, to knock it out from the rear using the bolts and putting it right on the hub assembly to torque it, no luck
tried heat, pb blaster over night no luck...
finally decided to take the whole knuckle off and went to town with a BFH, air chisel no luck. gave up and brought it into a shop where they would have a bigger compressor than what i have to knock it out. when i went to pick it up, they told me it took them 2.5 hrs to get it off.
once i got home, took a dremel with a wire wheel to take the corrosion off. that thing was seized bad!!
If you're going to tackle this job at home, be prepared for the worse. thing that gets me is the factory worker could have taken 5 seconds to put a coat of anti seize.....
edit: if i ever have to remove another hub assembly, i would just take the knuckle off and take it in somewhere for them to remove for me. no way i'd fight to get that thing off every again
