albertabound
- November 15, 2005
- Calgary, Alberta, Canada
- 1996 XLS 4WD
My 96 recently started making a squeeling/grinding noise coming from the RH front wheel. I put it up on jacks and discovered some play in the tire. After pulling off the tire, and some wiggling around it looks as if the rotor/hub assembly or bearings are the problem. Are the bearings easy to replace, or do I have to replace the whole hub? How do I recognize if it is auto or manual? Would anyone recommend going used on this stuff? Without being rich and equipped with proper set of tools, what do I need to do? Here's hoping someone has an easy, inexpenvie solution.
