gogogsr
- October 23, 2009
- Montreal
- 93 xl
Hey guys, i've noticed a klunking noise on the my driver side front wheel, so i decided to inspect it. I jacked the truck and checked for play, it's not the ball joints or the tie rod, i believe it's the bearing. So i went on and unbolt the wheel and did a bearing adjustment, etc. I noticed there was alot of side to side play on the axle (when i grab the splines and move them side to side, up and down, etc). Is it possible that the spindle needle bearing might be shot and is the culprit of this wheel klunking noise??? Thanks guys. Just so you know, i've tighten the bearing nut (2-3/8 nut) all the way in with my breaker bar and retigthen the wheel, just to see if the slack was still there, and it was, so i believe the wheel bearings are fine. Thanks guys
