jayishere74
- November 23, 2008
- akron ohio
- 2001 sport trac 4x4
I've had a rubbing/grinding sound in my front drivers side wheel for a few weeks now. I thought it was a warped rotor (sounded and felt like it) so i changed both rotors and put on new pads today. To my dismay, the noise is still there. I'm thinking that i have a bad wheel bearing. For the last few years, i've also had a problem with my ABS (the standard pedal skidding at low speeds). I changed out the rear wheel speed sensor and still have the problem so more then likely it's one of the front sensors.
My question is, what are the chances that the bad bearing is causing the abs to fail ?
Also, could the grinding noise i'm getting be anything else then a bad wheel bearing/hub ? It's the same at any speed, it feels like a pulsing that you get with bad/warped rotors.
Thanks !!
Jay.
Thanks !!
Jay.
