Wheel bolt pattern between the Flex & Explorer. | Ford Explorer Forums - Serious Explorations
Hello!
I am the current owner of a 2010 Ford Flex that may be bought back as a lemon and I'm considering the Explorer as a replacement.
I loved the Flex but I can't stand the thought of looking at another one in the driveway after all the bad experiences I've had with it.
I'd like to know if anyone knows if the bolt pattern for the wheels is the same between the Flex and the Explorer because I bought snow tires for the Flex that I would be able to swap out if the bolt pattern matches up.
Welcome to this forum! I've renamed your thread, and moved it into the tires & wheels section.
The bolt pattern on the flex and explorer are both 5X4.5 or 5X114.3 if you want it in metric. I want to say the backspacing is the same between the two as well, but I can't find anything to verify that.
Thanks. Was hoping I could use the snows from the Flex. Sounds Like I can.
