bennettcl
- April 8, 2007
- Olathe, KS
- 1998 Explorer Eddie Bauer
I think I might have a bad hub on the passenger side. It is a ton looser and easier to turn and sounds like it is grinding when you rotate it. I was wanting if that is a sign of a bad hub other then pushing and pulling on the tire to feel if it is loose. I believe the grinding sound that the Hub makes is the noise I've been hearing while driving around 30-40 mph. I thought it was my brakes, but now I believe it is the hub. So what are some major signs or a bad hub? Is the looseness/sloppiness a sign?
Also the spline from the CV axle that goes through the hub, does it need to be greased or anything when putting it all back together? Or do you just clean them up and put them back together???
I know how to take the Hub off and put it back on as I have it off already, because I am in the middle of replacing all my ball joints and control arm bushings and sway bar link. I just need to know how to tell if the hub is bad and if you need to grease the spline that goes through the hub. Thanks, CB
